hi, can somebody help me on what i want to achieve with the image, i want to have some color and texture when the visual style is on hidden line.
i want to have the water color and texture. will it be posible?
here there is an image of what i ant to do:http://screencast.com/t/pOSdDjjRsnYe
Solved by Jason_S. Go to Solution.
@Anonymous wrote:hi, can somebody help me on what i want to achieve with the image, i want to have some color and texture when the visual style is on hidden line.
Yes, Click on the item you want to change the color of, Right click and select from the flyout Override Graphics in View -> By Element.
When the View-Specific Element Graphics menu opens, go to the Surface Patterns section and change your color and patterns if you like.
To handle the Transparency drop down one to Surface Transparency.
Hope this helps you.
