I had a building conductued with different types of walls. When i tried to use filter to change the location line of walls, i found that i could not make it if the walls selected were different type, including materal, thickness,etc. How can i do to change all type of walls' location line to Finish Face Interior?
I can reproduce this behaviour you see. (See attached Screenshot)
What I have done is:
-Placed four walls.
-Inside one wall I placed a Curtain Wall.
-Selected everything and used filter.
-Unselected the curtain panel.
As you can see even after I unselected the curtain panel in my filter I only have "walls" inside the filter. However the "strange" thing is that I have 5 walls when you would expect 4. So still part of the curtain wall seems selected.
So some possible solutions.
-Make more elaborate filters.
or
-Select a wall, then "select all instances in project"(or in view). Then you would be able to change the location line.
-Repeat this for all different types of walls. (I expect not that many different types of walls?)
Louis
Please mention Revit version, especially when uploading Revit files.
