Revit Architecture
Active Contributor
mthemelis
Message 1 of 4 (108 Views)
hide walls in printing sections
108 Views, 3 Replies
09-10-2004 04:37 PM
i hide a wall in a section view and when i print the view the wall is there.
what am i doing wrong?
thanks in advance
mike
*Steve Burri
Message 2 of 4 (108 Views)
Re: hide walls in printing sections
09-10-2004 07:01 PM in reply to: mthemelis
From the documentation... -------------------------------------------------------------------------------- The Print command prints the current window, a visible portion of the current window, or selected views and sheets. When printing in Autodesk® Revit®, the output is "What You See Is What You Get (WYSIWYG)."; there are a few exceptions, however: a.. Regardless of what color you have for a background on screen, the background color on the print job is always white. a.. By default, reference planes, work planes, crop boundaries, and scope boxes do not print, even if they are visible in the view. You can print them by clearing the Hide check boxes in the Print Setup dialog box. b.. Elements that have been hidden from a view using the Temporary Hide/Isolate command still print. a.. Line weights modified by the Thin Lines command still print at their default line weight rather than the thin line weight. -------------------------------------------------------------------------------- ... it is working as designed. If you want those elements removed from the view for printing purposes, you need to manage them some other way... like delete them, print, then "undo" to undelete them. -- Regards, Steve Burri Autodesk, Inc Client Support Manager - Revit "mthemelis" wrote in message news:29416285.1094859508645.JavaMail.jive@jiveforum1.autodesk.com... > i hide a wall in a section view and when i print the view the wall is there. > what am i doing wrong? > > thanks in advance > mike
*v.valentijn
Message 3 of 4 (108 Views)
09-13-2004 02:09 AM in reply to: mthemelis
also moving them to another phase might give you what you want.. "Steve Burri" schreef in bericht news:41425c70_3@newsprd01... From the documentation... ------------------------------------------------------------------------------ The Print command prints the current window, a visible portion of the current window, or selected views and sheets. When printing in Autodesk® Revit®, the output is "What You See Is What You Get (WYSIWYG)."; there are a few exceptions, however: a.. Regardless of what color you have for a background on screen, the background color on the print job is always white. a.. By default, reference planes, work planes, crop boundaries, and scope boxes do not print, even if they are visible in the view. You can print them by clearing the Hide check boxes in the Print Setup dialog box. b.. Elements that have been hidden from a view using the Temporary Hide/Isolate command still print. a.. Line weights modified by the Thin Lines command still print at their default line weight rather than the thin line weight. ------------------------------------------------------------------------------ ... it is working as designed. If you want those elements removed from the view for printing purposes, you need to manage them some other way... like delete them, print, then "undo" to undelete them. -- Regards, Steve Burri Autodesk, Inc Client Support Manager - Revit "mthemelis" wrote in message news:29416285.1094859508645.JavaMail.jive@jiveforum1.autodesk.com... > i hide a wall in a section view and when i print the view the wall is there. > what am i doing wrong? > > thanks in advance > mike
Active Contributor
mthemelis
Message 4 of 4 (108 Views)
09-13-2004 11:45 AM in reply to: mthemelis
ok, thank you.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
