I'm asking if I can create a Diagram for my project like this diagram?? For circulation and sold & void spaces ...etc?
Solved by rosskirby. Go to Solution.
If you're using Revit 2014, then yes, you can easily create an exploded axonometric. Create a 3D view, set the orientation you want, and get started using the Displacement feature (select element, and on the modify tab, the view panel has a button that looks like a cube exploding, that's the one you want).
You'll have to monkey with it for a while to get things exactly how you want, and setting up the text is probably better done in a 3rd part graphics editor (i.e. Photoshop, Illustrator, InDesign, etc.) than natively in Revit, but it's possible.
agree with Ross....
I should ad that, maybe, you can do it also using a locked 3d View ,making Dulicates , using Section Boxes make a series of Views and at last make an assembly in a sheet.....
But , if I'll have to make a series of 2d with color schemes one on top of the other as in your example, I should use a trick ( maybe a bit unorthodox):
Constantin Stroescu
