ghost images
6 REPLIES 6
CONRADMILLER1056
813 Views, 6 Replies
ghost images
In any 3D view the glazing shows up as if it were in front.  Even the glass on the back side shows through as a color tone.  The perspective or iso is fine but any glass panel shows through.  This occurs in the "shaded" and "realistic" settings.  It is not evident in "hidden line" or "raytrace."  I've explored a number of visibility options to no effect.
Is this a glitch in my software?  Something systemic?  I don't see any comments or questions in the forums that address this issue.
Thanks.
CM
6 REPLIES 6
loboarch
in reply to: CONRADMILLER1056
Try updating your video drivers.  Revit 2013 has this problem with older display drivers with some video cards.  An updated driver should fix the issue.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
I also had this problem and once i updated my video driver it was taken care of - i have a nvida graphic card.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
scott_d_davis
in reply to: LisaDrago
I just updated my Nvidia drivers to a .88 driver number....it was the newest version on Nvidias website.  It fixed the "transparency" issue, but caused all kinds of other problems.  Revit would crash when leaving the materials dialog box.  Embedded "flash" animations/videos in web pages would crash, and more...i just rolled back my driver to the previous version.
So, be careful when updating drivers...the newest isn't always the best.  I have an Nivdia 1800m card.  The 880m is also having issues at this point.  Nvidia is working on fixes...
Scott D Davis
Sr AEC Technical Specialist
Thanks to all.  Updated re: Nvidia recommendation.  That seems to have solved the problem with no apparent "side affect" evident so far.
CM
Melissa.Stewart
in reply to: loboarch
We have had this issue as well and no about of driver updates or repairs/reinstalls has alleviated the issue. Any other ideas? Revit Arch 2013
loboarch
in reply to: Melissa.Stewart
You can try turning off hardware acceleration in the Revit options dialog found on the application menu (big purple "R").
Jeff Hanson
Revit Help |
