Hello.
Here is my problem :
I created my building and joined a topo file (with some neighboring buildings) (.rvt). I'd like to export the entire project (building+topo) to gbxml.
I've created my rooms in the two projects but when I join the topo file and export the entire project to gbxml there are only rooms of the building (neighboring buildings of the linked file have gone).
What do I have to do to keep neighboring buildings?
thx
Solved by cbcarch. Go to Solution.
You could try Binding the two projects into a single .rvt file, then export to gbxml.
I'm not sure if exporting function includes elements from linked files--but you could Link the Arch. model into the Site/Topo file, click the arch link and check the box in Properties to make the Link Room Bounding. This may give Revit info on the Rooms for exporting to gbxml.
I've done something like that and it works.
I've linked my topo file and then converted it into a group and it works.
thx
