Revit Architecture
Distinguished Contributor
Message 1 of 2 (269 Views)
from straight line to spline line
269 Views, 1 Replies
08-16-2012 07:12 PM
When I draw the detail line (DL), Is there a way to switch from straight line to spline line quickly?
It's kind of a pain to keep moving the mouse to the toolbar to change the line type.
I tried to assign a keyboard shortcut to the spline line but it didn't seem to work.
Thanks in advance.
Employee
bellesmum
Message 2 of 2 (248 Views)
Re: from straight line to spline line
08-17-2012 06:45 AM in reply to: diesellam
In Revit 2013 and later, there is a keyboard shortcut command called Default : Spline. If you assign a shortcut to this (I used DS), it will change the line type.
This was a bug that was fixed for Revit 2013, so it won't work in earlier versions of Revit.
Hope this helps you -
Lynn Poliquin
Senior QA Analyst
Autodesk, Inc.
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
