Hi all! i have to create a 3D model of a homes 1st floor to show how will underfloor heating system look like. but at first i wonna know can i do this or which application should i use? here are some sample models that i've found on the web. thanks
http://www.dizayn.com/yerden_isitma/16houseW_Copy.jpg
http://www.bambooindustry.com/images/blog/heat.jpg
it will be a basic model alrady i am not a professional 🙂
note: i am not good at English. Sory for grammatic mistakes.
It is possible in Revit, but I am not sure if Revit would be the best choice for this task. If it just for illustration purposes there might be other applications in which doing this illustrations might be easier, I don't know. Please see attached image. To create this view, I divided the floor with the Parts feature, then I created some generic pipes under the finish floor. Then, I locked the 3D view, and put a keynote, as an example.
