Guys
i have created a custom family base on Generic_Models_wall_based.rfa. the only thing i have put in is a rectangle opening in wall
measure it with width + height parameters + 2 parameters for the Sill Height and Head Height (U.K + O.K)
the target of it is to create a family for wall holes and tag it so i would have in drawing the Sill Height + Head Height
when bringing this family in project, the Sill Height does not work instead the Elevation parameter (instance param under constraints in properties)
controls the sill height of the opening thus the tag does not reflact the real U.K of the opening
how can i solved this?
does revit has a special tag for simple wall opening (i'm not talking about windows or doors just a hole in wall)
thanks in advance
Moshe
Solved by Paul_F_Aubin. Go to Solution.
Solved by Moshe-A. Go to Solution.
WHat you did is fine, but if you want to tag the parameters, they have to be shared parameters. Revit does not have a generic opening category. So if you want to use the built-in system parameters for sill height and head height, they would have to be doors or windows. If you prefer to keep them generic, then shared parameters is what you need.
Paul,
forgot to mention Sill Height + Head Height are shared parameters
Moshe
What category do you have the family set to? Is it Generic Model? If so then the tag needs to be set to Generic Model Tag. Then in the label properties dialog in the tag family, you click the small icon at the bottom left to add a parameter. There you shoudl be able to select your shared parameters.
Hope that helps.
Paul,
talked to a far coworker and he advised me that the only way to solve this (as you suggested) is to set the family as window category
as far as i'm concern this a poor solution cause this is not a window and i do not want it to be in windows schdeules.
thank you very much for your help
Moshe
Well, the window category does have the built in sill parameter, so that part is certainly easier. However, you should be able to use shared parameters to make it work as a generic model. If you want to post the file, I can take a look.
If you do end up going with window, try adding a Yes/No parameter (also shared) to the family so you can filter them out of the schedules.
Paul,
here is the families to play with, note the elevation pararameter (instance) that controls the 'sill height'
thanks
Moshe
by the way paul
what do you think about my previous thread?
have you got a workaround?
revit 2014 - underlay does not work in link
hi guys,
have a project (a multi story building) were the levels are link-in, i opened the linked 2nd floor (for example) and set underlay and underlay orientation as RCP to see all the beams benith the floor above in dash dot line style and it works fine. go to level 2 in the hosted project reload the link but the underlay beams does not showup.
what i am missing?
Moshe
I played a little with your family. Everything is set up correclty, and I can get the schedule and tags to report the values of your shared parameters just fine. However, I suspect that you really want the height above the level. Well this is the part that is not behaving. For whatever reason, Revit does not let us schedule the built-in offset or elevation parameters that control the location of these objects. This makes this a bit challenging.
I noticed you are on 2013. So you have to use a multi-category schedule. In 2014 and 2015 you can do a generic model schedule for what its worth.
I guess to truly get a sill height, you might have to resort to window. Sorry about that.
thanks paul (and don't be sorry)
i also test in R2014 and it's the same behaviour
Right. The only difference is you can schedule directly.
what do you mean by that (schedule directly)?
in R2013 i can not and in R2014/R2015 i can?
In 2014, they added the Generic Model as a category for schedules. So instead of having to do a multi-cateogory and filter other objects out, you can do a Generic Model Schedule.
