I have made an extruded wall and when I attempt to add a window I get this warning.
None of the created elements are visible in Structural Plan: Erdgeschoss View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings.
What am I doing wrong, please help
Hi.
Windows do not appear in structural plans.
I think you have started with a structural template.
Anyways, in the view instance properties, change the discipline to architectural and see if the windows appear.
go in elevation view or look in Properties ....perhaps the wall is somewhere at a very low level and the window that you try to insert is above the wall top level...it doesn't matter it is a structural wall
Constantin Stroescu
Thanks I think I am having issues with the view range. Does anyone have suggestions on what I should set what at.
The Cut Plane of Levels is by default 1.20 meters (see it in Properties> View Range)
When you insert a window look first in Properties to see the predifined Sill Height from Constaints. If the sill height is greater then 1.20 then the window is not cuted and it will not appear in your plan.
You have then two metods to show the window:
Constantin Stroescu
