Revit Architecture
Member
cookie4
Message 1 of 2 (121 Views)
exporting to DWG
121 Views, 1 Replies
11-12-2012 10:32 PM
I have to export my plans done in Revit 12 to DWG files so other Architect can work on them as he does.t use Revit at all.
My problem is that for instance, the Walls and the Hatch inside the Walls come as the same Layer in DWG.
another problem is the windows. Every line there inside the window is a diffrent layer. I understand this is for diffrent kind of lines, but in Autocad they use the same line and layer for all the window...
is there a solution i can give them for this?
thank you all in advance for your help!
Jennifer
CADastrophe
Message 2 of 2 (114 Views)
Re: exporting to DWG
11-13-2012 05:46 AM in reply to: cookie4
You can control (to a degree) what layers the Revit elements export to. Go to Application Menu (the big 'R') » Export » CAD Formats » DWG Files.
At the top left of the dialog box, there is an option 'Select Export Setup'. Click on the browse button (Browse.JPG) to customize the export settings.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
