Disconnect your network cable and try again. I have found there is something wrong with networks and revit, I don't know what it is, some point to the accurender libraries, if they are on a network it causes problems, I had the same thing, the model did finally export, just took forever. Disconnect your machine from the network or copy the file to your home machine and boom exports in a couple minutes.
