Hello everyone:
You see, when you import the CAD attached and generate the topographic surface in Revit, I miss erratically, with peaks like Mount Everest.
How to fix that?
thanks
Hi, thanks for replying:
But I have two questions:
First, if I delete certain points and contours do not lose information topography?
Furthermore, Autocad have different color lines and points.
Could you look at the file and give me some light, if not much to ask?
thanks
If you notice, the relief does not generate upwards ie leaves contours, flat.
this is the file: Topo 1
Under other, which generates the surface properly, for you to compare.
thanks
You only need the 3 layers your contour lines are done on, everything else can be removed.
Personally, i always spend 2 minutes cleaning the CAD file before use, check what layers your topo info is on and they are the only layers you need. In this case, the only layers you need are [Top], [Top1] & [TopCEI] you can delete everything else and save as a new dwg file. Make sure you remove the stray line you have floating around randomly.
Once you have linked the clean file into Revit, only select they 3 layers to generate the topo and you will have a topography. Works perfect for me with your file. See attached
Hi, thanks for your answer:
I was able to generate good surface, thanks to your instructions, but I do not understand why me leave me some purple lines that I see in your image.
A more fundamental question is the following, in The picture you see the view, watch the entire distance from the lines of levels to the surface where it really begins.
This applies when you decide to make platforms for calculating the movement of earth?, How do I correctly place the surface in Revit, so that the calculation of earthwork is correct? That is what I put level, and from where I can start putting construction platforms?
thanks
hello, thanks:
I would like to know something. We know that there is a difference between creating a topographic surface points, or import a file with contours.
When you create points, I can create multiple levels in Revit and tie each of these nivees my point curve, but
When I import a file with Autocad level curves, how to put in as Revit levels further if the file brings many curves? (For example, with differences of ten centimeters).
thanks
