I have a dual screen monitor setup. All windows programs (and formerly revit) are set up to treat the 2 monitors like one continuous monitor (discregarding the line between the two). I just installed the Revit maintenance update and now the 2 monitors in revit only will not allow a window to display stretched acress 2 screens: Revit pops a display to one screen or the other when a revit window is maximized or when I try to strectch acorss 2 screens. I want Revit to treat the display as one continuous screen with no snapping to the individual screens (like all other windows programs. There are no video card setting for this behavior: there must be one for Revit. Does anyone know where it is?
What Revit version do you have?
Which update version you installed?
Did you reboot the computer since the update been installed?
Try to Close revit and deactivate one monitor and reactive it then try to open revit
So if you want Update 2 to be applicable 100% you need to have administrator privilege
here is a link for how to add admin right to your name
http://www.sevenforums.com/tutorials/122666-permissions-allow-deny-users-groups.html
