Show only
Search instead for
wrote in message news:5370246@discussion.autodesk.com...
Is there a way for force REVIT to display the door and window tags in their
respective schedules?
Tag report value from the object itself. Exactly like schedule. So you need to figure out which parameter is used in your tag and add them to your schedule.
Are you confusing with the "Type Mark" (type parameter) and the "Mark" (instance parameter).
Typically architects use Type Mark for windows and Mark for doors...
