Revit Architecture
*David Metcalf
Message 1 of 3 (141 Views)
dimension String placement
141 Views, 2 Replies
09-24-2004 02:52 PM
Can anyone give me a tip to control the dimension string placement 5' from a wall face on plan? Thanks David
Distinguished Contributor
Message 2 of 3 (141 Views)
Re: dimension String placement
09-28-2004 10:30 AM in reply to: *David Metcalf
just place a detail line where you want it, then drag the dim to that location. Revit lets you set the offest between dimensions strings in the property of the dimension, but not from objects.
*David Metcalf
Message 3 of 3 (141 Views)
09-28-2004 03:03 PM in reply to: *David Metcalf
Alrighty, I was hoping some form of drag and type the distance to offset the dimension string from. "sdbrown" wrote in message news:21048241.1096392635083.JavaMail.jive@jiveforum2.autodesk.com... > just place a detail line where you want it, then drag the dim to that location. Revit lets you set the offest between dimensions strings in the property of the dimension, but not from objects.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
