Revit Architecture
Member
barrydeister
Message 1 of 7 (560 Views)
datum elevations
560 Views, 6 Replies
06-18-2012 12:08 PM
If you have multilple levels in a multi-story building and you want all the datum elevation tags for each level in a building section to read "T.O. Concrete". How do you accomplish this ?
Valued Mentor
vector2
Message 2 of 7 (547 Views)
Re: datum elevations
06-18-2012 05:18 PM in reply to: barrydeister
Every level has to have a different name because it's a different level.
Member
barrydeister
Message 3 of 7 (540 Views)
06-18-2012 06:58 PM in reply to: barrydeister
Can you hide the parametric datum elevations and add dummy elevations in each view?
Valued Mentor
vector2
Message 4 of 7 (524 Views)
06-18-2012 09:42 PM in reply to: barrydeister
I tried to unravel the mysteries of your question, but I failed.
*Expert Elite*
LisaDrago
Message 5 of 7 (512 Views)
06-19-2012 05:08 AM in reply to: barrydeister
I guess ultimately - what are you looking for?  Every level or reference datum needs to be unique as stated. You can always hide the datum's if you want and just put in some symbols and text. But if something moves - you will have to go back and move everything with it. So you loose some of the base functionality of the software.
Your revit files will not look exactly like AutoCAD - that is not a bad thing - but it is a change which is never easy.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
*Expert Elite*
Alfredo_Medina
Message 6 of 7 (506 Views)
06-19-2012 06:50 AM in reply to: LisaDrago
Levels must have unique names, but it is up to the user what to display in the level family . If, due to the kind of work that the user is doing with Revit, he is not interested in showing level names but just in showing a note, such as "T.O.Concrete" in all of them, then, the level family could be modified. The actual name of each level will continue to be "Level 1" , "Level 2", but the level family will show just the value of "Note", (for example), a shared parameter that is included in the family and added to the project. Another option is to leave both labels in the family, "Name" and "Note".
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Valued Mentor
vector2
Message 7 of 7 (493 Views)
06-19-2012 07:36 AM in reply to: barrydeister
Here's what I was about to post and then I thought maybe you
are not talking about levels but elevations. Interesting anyway.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
