cut 1 solid with another?
5 REPLIES 5
1315 Views, 5 Replies
Is there a way to cut 1 solid with another?
Or must I always create a void in the form that is to be cut, then stick the 2nd solid into the void?
5 REPLIES 5
ryan.duell
In Revit 2011, you can cut one solid with another solid.  I have included additional information below:
http://docs.autodesk.com/REVIT/2011/ENU/filesUsersGuide/WS1a9193826455f5ff-71bc797a126fd6fb25b-7ed9....
This functionality is limited to the conceptual mass environment or when creating a single in-place component mass.
Ryan Duell
Thanks.
I tired something like that, but it didn't seem to happen. I will persevere.
B
Alfredo_Medina
It works within the limits stated by Ryan in his reply: in the conceptual mass environment or in a single In-place mass.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
thank you all.
amoeba_720
You can also do this by setting the material properties as the same and joining them together, once you do this you can hide the element you don't want in view or place it on a workset like 'invisible' and uncheck that in the VG interface! I do this all the time to get the desired profile on Curved walls that need a sloped bottom for instance.
I hope this helps!
cheers!
