custom materil problem
1 REPLY 1
alexkonieczka
169 Views, 1 Reply
i wanted to make a 1/2" coated wire mesh material. in acad i renered a 1/2" section to file.
then in a paintshop i made a tansparent image and cutout png file.  both have the same dimensions and bit count.
in revit i made the material from image and it looks great but when i apply the cutout it does not line up with the same scale settings applies to both.  thanks, alex
1 REPLY 1
When setting up the material image, and the cutout, make sure that the scale listed for both is the same. I found when I setup a new material, even though the size of the two images were the same, the defaults for scale were different.
Material ImageCutout
Lance Coffey
Technical Support Specialist
