crown molding
6 REPLIES 6
2045 Views, 6 Replies
crown molding
can anyone tell me how to get crown molding on the tops of my cabinets? thank you John Krcil
6 REPLIES 6
In place family, sweep will do it. "John Krcil" wrote in message news:401c6efd_1@newsprd01... > can anyone tell me how to get crown molding on the tops of my cabinets? > > thank you > > John Krcil
You could also create a wall with the crown profile pre-set as a wall sweep. This would allow you to "draw" the molding and edit the profile a little more directly. You will want to make sure that the walls created with this type do not have the "Room Boundary" check box. Sincerely, glynnis patterson, Architect RAND IMAGINiT www.rand.com/imaginit
cbcarch
Another possibility:
Add the crown molding in the casework family as a sweep, using a Profile.
Make sure to use reference planes and lock the model geometry of the crown mold sweep to then so the molding will "flex" when you change cabinet sizes.
Create Visibility Parameters if needed to either show or hide the crown molding once loaded into the project.
For end cabinets, use the Visibility controls/parameters to turn the molding on/off inside the project depending on your needs.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
in reply to: cbcarch
@cbcarch, Cliff, you realize how old this post is right?  Thanks to the spammer for digging it up.
Yeah, babies were born when this thread started can have babies of their own today.
RDAOU
in reply to: ToanDN
Smiley Very Happy
I love this!!!!
