im a new user of revit massing , im using it to create an architectural site ,like neighboring blds n such. so when ever i try to create a mass it turns transparent as if its in wire frame mood and i cant add materials to it .
another question please 🙂 is it possible if i have a model created in sketch up or in acad 3d to create a mass of it in revit ?????? thanks in advance
Solved by constantin.stroescu. Go to Solution.
Mass Elements are semitransparent because they are made mainlyly to be a frame for Wall by Face, Curtain Wall systems, Roof by Face or Mass Floors - being so it'easier to work with them
You can import dwg or skp file into Revit but you are limited in editing them....
Constantin Stroescu
Just a tip for a workflow that I use for simple cubes to model the surrounding buildings.
I have edited the library simple cube conceptual mass - and made the material a 'Type' parameter, but left all dimensions as 'instance'. I also removed the 'Eq' restrictions from the origin for the dims.
I can then place the boxes on an Autocad underlay of the site, and lock the box sides to the plan rectangular outline. I can also set up 'Types' for each colour or material that I want to use on the context model.
Having set up the different colours by Type, you can easily switch materials for each box by swapping out Types for each box.
By locking the mass box to the underlay (and removing the Equal restrictions on the block), if the autocad layout is tweaked, the boxes automatically update (so long as you don't delete or add/omit any geometry from each block). If you don't remove the EQ, the boxes are locked to the origin position too, and any update on the Cad drawing causes constraint errors.
It's a handy way of blocking up a contextual model pretty quickly. Obviously, if your forms are more complex, you are probably better sticking with In Place Masses, and use an extrusion etc. But the simple box method saves quite a bit of time.
Martin
