color plots
1 REPLY 1
jdcho
365 Views, 1 Reply
color plots
Not sure if this is a revit issue ot not but I've been having issues with plotting in color.  I have a sheet with rooms designated with different colors for different departments.  I upgraded to 2013 and now can't plot color.  I have view template correct, the print setup to plot in color, and everything else seems to be right.  Any ideas?
Running win7, 64bit, 2013 building systems.  And I know the plotter is fine, plotted in autocad and pdf's were fine in color.
1 REPLY 1
jdcho
in reply to: jdcho
Not sure what did the trick, but I updated to the latest update on Revit 2013 (update2) and updated all the HP drivers.
Now I'm plotting in color.
