central file
3 REPLIES 3
611 Views, 3 Replies
central file
Hi everybody,
I have tried to make a central file on the dropbox, but it doesn't let me (in the dialog box the central file is grey so i can't even change it). Are there any other possible ways to make a central file so i could work with y collegue on the distance?
thank you in advance.
3 REPLIES 3
ryan.duell
You will need to have a location all users can connect to in the same manner; this is the only method it will work if you want to be able to work with the central file at the same time.
A similar post on using Dropbox:
http://revitoped.blogspot.com/2010/06/dropbox-and-project-sharing.html
Thank you,
Ryan Duell
in reply to: ryan.duell
Hi again,
I have a problem when i want to make my file as a central. When i save as new project, then change name of it and then in the options the button appears grey and doesn't let me make a central file, what should i do?
thanks again
hei, finaly i have created the central file and it seems to work, i can sync and my collegue as well, but we don't see each others changes. there are in common folder files named as conflicts. therefore i have no idea what to do.
thanks for the help
