Revit Architecture
Distinguished Contributor
oracle
Message 1 of 3 (1,151 Views)
cant change my wall height?
1151 Views, 2 Replies
07-21-2008 07:36 AM
for some reason (and this is a reoccurring problem) i cant change the height of some of my walls. this first time i had this problem it was only a couple of walls so i redrew them. but now its a lot more than that so i want to figure out how to fix the problem and prevent it from happening again. the height is unconnected and no matter what view im in the top grip arrow is not showing. can someone help with this please?
*ijnicholas
Message 2 of 3 (1,151 Views)
Re: cant change my wall height?
07-21-2008 07:43 AM in reply to: oracle
The walls may be attached at the top. In this case, changing the wall height
would not change anything. You can select the wall and select "detach' from
the options bar and then click "detach all" in the options bar
nicholas iyadurai -
Tirunelveli
http://revitize.blogspot.com/
wrote in message news:5986400@discussion.autodesk.com...
oracle
Message 3 of 3 (1,151 Views)
07-21-2008 08:22 AM in reply to: oracle
thanks a lot exactly what the problem was.
revit is too easy sometimes.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
