The walls may be attached at the top. In this case, changing the wall height
would not change anything. You can select the wall and select "detach' from
the options bar and then click "detach all" in the options bar
nicholas iyadurai -
Tirunelveli
http://revitize.blogspot.com/
wrote in message news:5986400@discussion.autodesk.com...
for some reason (and this is a reoccurring problem) i cant change the height
of some of my walls. this first time i had this problem it was only a couple
of walls so i redrew them. but now its a lot more than that so i want to
figure out how to fix the problem and prevent it from happening again. the
height is unconnected and no matter what view im in the top grip arrow is
not showing. can someone help with this please?
