cannot snap to the casework after importing the 2d CAD file
3 REPLIES 3
diesellam
384 Views, 3 Replies
I tried to move the toilet and lavatory to align with the 2d CAD file that has the fixtures layout.
But after I imported the CAD file, I can no longer snap to the end point of the fixtures to move.  if I delete the imported CAD file, I can snap to the end points of the fixtures again.  What's the reason of it?
3 REPLIES 3
Lance.Coffey
in reply to: diesellam
When you are importing the CAD file, do you have the checkbox "Correct lines that are slightly off axis" checked?
Lance Coffey
Technical Support Specialist
diesellam
in reply to: Lance.Coffey
To import the CAD file for the layout of the casework so that I can start inserting the casework family accordingly.
The box is checked.
Lance.Coffey
There are a few things that could be tried to get a better idea of the scope of the issue:
- Make sure you have applied any updates available for Revit.
- Create a new 2d CAD file and import into project to see if the issue is with the imported CAD file.
- Create a new project and import the existing 2d CAD file to see if the issue is with the original project file.
- Check if the snapping issue is specific to one or more of the views in the project.
- Try exploding the 2D CAD file after importing it.
- See if you can snap to geometry other than the imported CAD file.
- See if you can snap to the geometry of the imported CAD file with different elements (from the toilet).
Lance Coffey
Rail Community
