Revit Architecture
Active Contributor
rudolf.vyhnalek
Message 1 of 5 (182 Views)
can't sync with central - stacked wall type missing
182 Views, 4 Replies
12-04-2012 09:09 PM
we are expiriencing very strange error which blockes users so they can't work in team. It started when we found that there is no stacked wall type in a project. i don't know how this could happen since you must have at least one type active because it is a system family which can not be deleted. so I transfered project standards from a template so I get default type in a project and save. When just one user is working wi
th the project (has own local file) it works fine but anybody else when tries to sync with central gets a message that he has no stacked wall type in a project and the file can't be synchronized even if there is default stacked wall type visible in project browser. So I turn off all worksets, added new stacked wall type, save and make it central again. but the error is still there.
can somebody help me with that?
thx a lot
Rudolf
Active Contributor
kentw
Message 2 of 5 (178 Views)
Re: can't sync with central - stacked wall type missing
12-04-2012 09:57 PM in reply to: rudolf.vyhnalek
G'day Rudolf,
Based on the description of your issue and methods used to try and solve it, I would immediately log it to Autodesk as a corrupt file for them to repair.
_________________________________________________________________
KarelCAD Application Support Specialist
Active Contributor
rudolf.vyhnalek
Message 3 of 5 (173 Views)
12-04-2012 10:40 PM in reply to: rudolf.vyhnalek
thank you for reply. Is there a way how to do it directly? Or do I have to ask the dealer/distributor to log it via partner center?
Thank you.
Rudolf
Active Contributor
kentw
Message 4 of 5 (168 Views)
12-04-2012 11:10 PM in reply to: rudolf.vyhnalek
You can log support calls via the subscription centre.  Here is link to a video describing how to do this.  You can also log it to your reseller and they will log it to Autodesk on your behalf.  They may request your serial number to do this.
http://www.youtube.com/watch?v=GrJ2H6cOJ2c
Member
Garrett_hardy
Message 5 of 5 (33 Views)
07-07-2014 12:55 PM in reply to: kentw
Did you ever get a resolution for this or how to fix it. I am experiencing this with a project. But I am the MEP engineer on the project and believe it may be a corrupted Arch file. So I was curious if anything ever came of this.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
