In an elevation view, hover your cursor over one of the brick lines. Using
the TAB key, you can cycle through and select that coursing line. Then use
the Rotate tool to rotate it to the desired angle. The rest of the pattern
will follow.
Matt Dillon
Autodesk Architectural Desktop Certified Expert
View my ADT Blog "Breaking Down the Walls" at
http://www.modocrmadt.blogspot.com
wrote in message news:5394352@discussion.autodesk.com...
DOes anyone know how to align the brick pattern on a wall so it is at an
angle. IE a curtain wall panel that has been converted to a 4 inch brick
wall....i would like the course to be at 45 degrees rather than at a
horizontal plane....
