Revit Architecture
Valued Contributor
Joris3P
Message 1 of 4 (2,277 Views)
beam not visible
2277 Views, 3 Replies
05-17-2010 12:32 AM
Revit Architecture 2011.
Problem: a drawn beam isn't visible / selectable.
Steps I took:
Structure > Beam > selected a beam > on first floor plan
Section shows the drawn beam. However I can't selected / move /see the beam.
The beam is below the first floor so that I can't see the beam is logical to me.
When I go to the level below (basement) I don't see any dotted lines indicating a beam above it. And again the beam can't be selected.
My questions:
* how do you work with beams in Revit (adepting vis.settings everytime?)
* how does Revit show beams above the cutlevel (a dotted line). If not standard: is there a workaround?
Kind regards,
3Pinter
*Expert Elite*
ccollins
Message 2 of 4 (2,277 Views)
Re: beam not visible
05-18-2010 02:14 PM in reply to: Joris3P
Perhaps make a Level or a Reference Plane to locate the beams on, and then work in that work plan or plan level
when editing beams.
cheers
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
Distinguished Contributor
krispy
Message 3 of 4 (2,277 Views)
05-18-2010 09:33 PM in reply to: Joris3P
in the view properties set the "Underlay" to be the same level of the current view and the "Underlay Orientation" to "Reflected Ceiling Plan". (See Attached).
New Member
aaurnab
Message 4 of 4 (102 Views)
07-03-2014 02:46 AM in reply to: krispy
I want to omit the slab lines
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
