hi all,
i have an issue,
i installed autocad 2011 revit on xp sp3 32bits, evrything is fine except that when i try to open a file , i have the error message about that my local hard drive is not enough free(but 400go free space are available...) and that i need to change my user variable TMP of folder????
any ideas?
thanks
Solved by kathryn.langan. Go to Solution.
Typically the message that there is not enough space on the C drive is due to the Windows temp folder being too full. You can try the following:
Clear the folder out:
If that doesn't help, you can try redirecting the temp folder:
Please let us know how it goes!
Very very thanks for this kind suggestion. I've been suffering for this from 2 mnths ago. I was using W -7, W-Vista but now setuped w xp only to free space of c(though there is 27 gb+ free). I was confused about that warning. Now I got my ans.
hi,
first of all thanks for your answer.
unfortunatly it doesn't change anything, indeed i also make a new partition where i create a new folder and change the path of the this variable and i still have the same message that the folder don't have enough to create temporary files for revit...
just let you know that these files have been created in autocad 2011 revit on a windows xp sp3 64bits and i try to open these autocad files on a windows xp sp3 32 bits, don't know if there is any impact...thanks for you help
regards
When working on the BIM 360 file, the temp files are still stored in CollaborationCache folder in the C:\Users\username\AppData\Local\Autodesk\Revit\Autodesk Revit 2019. I am unable to redirect it to other drives
