Revit Architecture
Valued Contributor
amontri
Message 1 of 2 (166 Views)
Accepted Solution
advice on one file with several buildings or separate files for each?
166 Views, 1 Replies
11-22-2013 09:08 AM
If I have a cluster of buildings all within the same area, each building several floors, should I keep them all together in one file for energy simulation purposes (in case there are shading effects), or should I separate them out into its own file?
Product Support
Zsolt_Varga
Message 2 of 2 (88 Views)
Re: advice on one file with several buildings or separate files for each?
11-27-2013 08:11 AM in reply to: amontri
If you have several buildings in the same building-site and you want to run an energy analysis on them, then you basically have two options.
1. Build all the buildings in one project file. This I only would suggest if the buildings are connected to eachother with building elements such as walls, floors or rooms and you are sure, you aren´t generating  a huge file size, which could cause a slow performance of Revit.
2. You set up different files for each separate building and link them together in one host file. You can run energy analysis and get results for all those linked buildings.
Shadows, that buildings cast over each other are not affecting the calculation of Energy Analysis.
Check out these videos to find out how to link and position different buildings:
https://www.youtube.com/watch?v=rWWxdsPl-fQ
https://www.youtube.com/watch?v=-A1cxbPD5ds
https://www.youtube.com/watch?v=vum9xSrWw84
http://images.autodesk.com/flashassets/staticassets/images/autodesk_logo_signature.png
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
