Did you try to pick parts of the wall away from the modification? I think
the rebar looks to be part of a slab or wall object. The modification may
not react to a pick as a wall object.
Try putting rebar in a monolithic stair made of concrete. The rebar routine
won't highlight the stair. Rebar needs work.
Arthur
wrote in message news:5481235@discussion.autodesk.com...
I am unable to use the "sketch rebar" command with a concrete wall that I
have given a modified profile. I created an arched opening and want to show
reinforcing in its legs. I know i can just draw it in 2d, but is there a way
I can get smart rebar to see my profile?
