There a few ways to get a leader with no text..... However from what you
describe you need to look at your symbol family. If it was made as a
generic annotation, your symbol should have the option for adding leaders,
just add 4 leaders and position them as desired. Look at the keynote family
as a good example.
hth,
Z
"cchong" wrote in message
news:7785035.1102538957101.JavaMail.jive@jiveforum1.autodesk.com...
> I have created a symbol with text attributes that I could modify. In this
case the symbol is a "EWA" (exterior wall assembly) that I intend to add
arrowhead leaders at four directions to indicate the extent of the wall type
on a building elevation.
> Is that a way to add a leader with arrowhead (with no text) to the symbol
after I placed the symbol on the view? I do NOT want any extra text to
associate with the leader. Just a plain, straight leader as graphical
element that I could move, rotate and stretch. The result should look
something like this:
> <----------(symbol)---------------->
