Look up "shared parameters" & "project parameters" in the help file. You
create the parameter in the family as a shared parameter, then you go into
the project and create a project parameter (Settings -> Project Parameters)
that tells what catagory that parameter should be.
wrote in message news:5445100@discussion.autodesk.com...
I've created, on sheet, a frame where I placed some standard labels wordings
and others that I've created and renamed myself.
The problem is that when I insert this cartouche in a project, the labels I
created appear as a question mark, and they are not actives as labels
How can I correct this?
I want to create active labels wording specific to our office and not the
preset one.
Any help would be appreciated. Thanks!
