accented capitals problem...
3 REPLIES 3
Marlec
253 Views, 3 Replies
I have a problem with accented capitals...
Instead of seeing " Â " (on screen and printed),  I get " Á "...
the problem is only in Revit, nowhere else... when using "text annotations"
3 REPLIES 3
AJA14
in reply to: Marlec
Hi. Not sure if this helps but try it.
Go to the start menu and type char, choose the character map, and make sure that the shortcut you're using will give what you're looking for.
If I misunderstood please let me know.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
Marlec
in reply to: AJA14
yes you misunderstood...
the pronlem is in Revit only... Cad, Office... everything else is worjing just fine...
AJA14
in reply to: Marlec
Hi. I created various different characters and everything appeared fine. Maybe it has to do with graphics or compatablility. Good Luck.
Ali Al-Hammoud
