Revit Architecture
*Alain Martini
Message 1 of 3 (143 Views)
X Y Z !
143 Views, 2 Replies
05-19-2004 01:09 PM
Hello, I have an excel file containing X Y Z coords of points (issued from a survey). these points are describing 3d open polilines. What is the best way to import those points for using in a topo surface? (obviously without using other external tools) If external tools are needed what tools you suggest? specify if these are free. I have read the good toposurface tutorial, but the tutorial dont specify if there is a way to set x y precisely but only the elevation. Thank you in advance! --- Alain Martini http://www.inalto.com
*Aaron Rumple
Message 2 of 3 (143 Views)
Re: X Y Z !
05-19-2004 03:31 PM in reply to: *Alain Martini
Not easy in anything but civil software. With the software I have I would use a script to import the points into AutoCAD. Import the 3D point cloud into Viz. Make a mesh of this. Slice the mesh at my contour intervals. Export the generated plines as AutoCAD DWG. Import the DWG into AutoCAD and Revit will make my topo from that. I think I could make a journal file that would create the topo surface, but wouldn't be a simple thing.... Have to give it some thought. "Alain Martini" wrote in message news:40abbf23_3@newsprd01... > Hello, > > I have an excel file containing X Y Z coords of points (issued from a > survey). > these points are describing 3d open polilines. > > What is the best way to import those points for using in a topo surface? > (obviously without using other external tools) > > If external tools are needed what tools you suggest? specify if these are > free. > > I have read the good toposurface tutorial, but the tutorial dont specify if > there is a way to set x y precisely but only the elevation. > > Thank you in advance! > --- > Alain Martini > http://www.inalto.com
*A.Seven
Message 3 of 3 (143 Views)
Re: X Y Z !
05-19-2004 03:38 PM in reply to: *Alain Martini
this might be it: http://www.tushar-mehta.com/excel/charts/3d_surface/index.html "Alain Martini" escreveu na mensagem news:40abbf23_3@newsprd01... > Hello, > > I have an excel file containing X Y Z coords of points (issued from a > survey). > these points are describing 3d open polilines. > > What is the best way to import those points for using in a topo surface? > (obviously without using other external tools) > > If external tools are needed what tools you suggest? specify if these are > free. > > I have read the good toposurface tutorial, but the tutorial dont specify if > there is a way to set x y precisely but only the elevation. > > Thank you in advance! > --- > Alain Martini > http://www.inalto.com
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
