Worksharing monitor 2012 not working
2 REPLIES 2
wouterbleumink
1202 Views, 2 Replies
Hi all,
i want to use the Worksharing monitor with Revit Architecture 2012 SP1 64 bit (part of our building design suite premium), but when i load a workshering-enabled model (wich resides on our Revit server) the monitor stay's empty (stating that i should open a model in Revit)
Any ideas on how to solve this?
Wouter
2 REPLIES 2
LisaDrago
in reply to: wouterbleumink
The worksharing monitor does not work with the revit server. No way around it (other than taking the project of the revit server.)
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
wouterbleumink
in reply to: LisaDrago
Thanx for the info... to bad that this does not work... would be a great asset.
