"You only create a local file once."
Yes, if it never becomes out of date sync with the central nor corrupt.
"That local copy stays on your machine after you close out for the day."
Yes.
"The next day when opening the local copy it synchronizes with the central
file,"
only when you 'save to central'
"it does not actually copy the file onto your local drive again."
Correct.
"When saving to Central, once again, it synchronizes the files and does not
copy the entire local file into the Central file."
Correct.
"Can anyone give me some examples of how long the synchronizing process
takes?"
normally 5-10 seconds on the project I am currently working on but this
could be up to around 20-30 seconds if many changes have occurred from
different users since my last 'save to central'. (on our gigabit network
the central file sits on a linux server - this is an ideal configuration as
it works great!)
"This would effect the network traffic and determine what time increment we
use as a default to save to the central file. I've seen a
suggestion of saving to your local every 30 minutes and every 1-2 hours to
the central file. Does that seem like a good guideline?"
I like the 30min. reminder. users may skip a few if they are in the middle
of a modeling task then save on the next one (=2hr) - if set to 2hr and skip
one its half a day.
Brian Earsley
www.arete3.com
708.342.1250 x.225
New to DWF? Check it out!
http://www.arete3.com/services/communication.html
select "ARCHITECTURE" - "File Formats"
"Nancy" wrote in message
news:5403297@discussion.autodesk.com...
Are the following assumptions correct:
You only create a local file once. That local copy stays on your machine
after you close out for the day. The next day when opening the local copy
it synchronizes with the central file, it does not actually copy the file
takes? This would effect the network traffic and determine what time
increment we use as a default to save to the central file. I've seen a
