Thanks - I was wondering about that with REVIT. I know it is unuseable with
ACAD.
"i will not bill you for this:)" - you can try! ;-}
I will look into the Cisco PIX. Thanks again.
Cheers Peter,
"Brian" wrote in message
news:5705969@discussion.autodesk.com...
yes - works fine for Revit not for Autocad/ADT/ACA where quicker response
times are expected.(T-1(1.5mps) on office side/cable 7-8mps on my side) i do
not use PC anywhere - get a Cisco PIX
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/ and use remote
desktop.
for ACAD - copy DWG files to home pc revised and copy back to office. all
projects require communication with team of course.
best wishes...
Brian Earsley
www.arete3.com
18645 South West Creek Drive
Tinley Park, Illinois 60477
708.342.1250 x.225
"Peter" wrote in message
news:5705915@discussion.autodesk.com...
Brian - Do you currently do this? When I was using PCanywhere to transfer
files for remote working, I tried to work a bit on ACAD and found it
impossible with the lag over the internet. Both connections were cable
modems. I can't see it working very well that way. Is there a way to
transfer the file only and work on it on a local machine, where ever you
happend to be, and then copy it back when you are done working? It also
means it frees up a computer at the place where the server/main file is
stored.
Regards Peter.
news:5705948@discussion.autodesk.com...
the user file sits on a local machine gigabit cabled to the server that has
the central file. you VPN into the local machine and use revit on that
machine. the VPN only transfers screen shots and your home machine only
runs remote desktop.
Brian Earsley
www.arete3.com
708.342.1250 x.225
wrote in message news:5705552@discussion.autodesk.com...
If I'm understanding these last two posts, you are just using a remote
desktop application (through windows)? I have my workstation connected to a
router which is then connected through a VPN to the server at the main
office. I cannot work on files that have been setup with worksets because
even the smallest tasks, like adding a dimension or deleting a window, take
5 to 15 minutes to do. I've tried checking out worksets and turning off the
ones I'm not using but it still seems to need to keep that connection to the
central file on the main server which has to run through the VPN and even
with high speed internet takes a really long time. Then there is saving
back to the central file, which can eat up almost 45 min on some larger
projects. I'm wondering if our IT guy is going about this the wrong way?
I'm not network literate enough to have it out with him so if someone can
give some specifics to take back to him that would be great.
