Revit Architecture
Active Contributor
NigelParsons4560
Message 1 of 2 (320 Views)
Witness Lines Disappear
320 Views, 1 Replies
10-31-2013 06:16 PM
I click on my wall, drag the end of a witness line to a new point and the whole thing disappears, preventing me from changing the value of the witness line.
Also, I'd like to be able to add a witness line.  is it possible?
Distinguished Mentor
Caddman13
Message 2 of 2 (275 Views)
Re: Witness Lines Disappear
11-01-2013 02:09 PM in reply to: NigelParsons4560
Not sure I fully understand your first issue, but to change the length of a wall or any item, Pick that item then click on the dimension and type in the length.
For adding witness lines pick the dimension and then on the Ribbon Click edit witness lines.  That will allow you to add or subtract witness lines from that dimension string.  See attached
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
