Does anyone know how to add trim or diagonal sweeps to a curved wall. I have a circle top window in a curved wall and I need to add 1x4 trim around it.
Solved by constantin.stroescu. Go to Solution.
to add trim to a arched window:
A
C
In order to make a diagonal sweep you can use as path for the sweep the intersection of the wall with an Extruded Component Model in Place....
Constantin Stroescu
