Please see attached images.
Im trying to insert windows, as per attached image.
Would appreciate any help with it.
Solved by constantin.stroescu. Go to Solution.
You will need to add some 90 degree/plumb walls and place the windows in them, as well as infill walls at the jambs and a soffit at the head condition.
The problem is that the entity is roof and wall in the same time...
I use two methods for solving the problem:
image 1.
image 2.
Your Name
Constantin,
The "wall" the doors go into is not 90 degree/plumb, it is slanted.
So the doors need to be inserted into a 90 deg./plumb wall, and then jambs and head condition infilled.
agree with you...anyway in my post, the first method , I used a vertical wall in wich I placed all the windows, doors, curtain walls and I enveloped it with the extruded roof....You are right ,between them it is necessary to place conection elements border frames (jambs,head,sill) because there are gaps..so as it is done on worksite........
I heard a rumour that in Revit 2014 there are slanted walls...is it true?
Your Name
Slanted Walls? Nope. That was my annual April Fool's joke.
13th year now, Revit has no Tilt Wall function..........
