I created that window family I mentioned in my earlier posts.
The window type showed up in the window schedule. But the window dimension didn't.
What's the reason of it? I know you can enter the dimension directly into the schedule. But it would be nice if it comes it automatically. See attached file.
Thanks in advance.
Solved by CoreyDaun. Go to Solution.
There is no default value defined in the Family, so the parameter values will be initially blank in the Schedule.
If you want these to come in automatically, then input a default value for each Type that you create.
Your window family does not have any dimensions or parameters associated with any objects.
I`m having the same problem. And my family has the parameters but the door schedule, doesnt recognize it.
Thanks in Advance
Ramon
