Using demo version of 2012 Revit Architecture.
Need to know how to change the profiles used for door, window trim.
Default is flat casing from what I am able to determine.
I want to change to say 3-1/2" beaded casing or Adams casing. How do you do this.
taoist53
You would need to edit the door family and add the trim as you would like.
I would use a sweep and create the profile you want to see for the trip.
LD
