Window Trim in Revit
6 REPLIES 6
SDG-Kelly
12536 Views, 6 Replies
Hey all,
Dose anyone have a good method for adding a very specific window/door trim to a project without customizing each and every window/door family project wide? Thanks for any help you can provide.
6 REPLIES 6
melarch
in reply to: SDG-Kelly
You create a faced based family or use the Create In-Place tool under the Modeling tab to create windows trims using a sweep.
Mel Persin, aia
Scott_Womack
You can also add the trim to the window families, with a Yes/No instance parameter to control the visibility of the items.
leila.k.sh
in reply to: Scott_Womack
Hi Friends, Is there a good tutoring movie regarding creating a trim in window family? Any help would be appreciated.
chrisplyler
It may be adequate - depending upon your modeling requirements - to simply create the trim as both a front view and a side view detail components, and place it into section details where necessary, without actually modeling anything whatsoever.
Or...
I've done an adaptive family for a soldier course arch (just for example), which I could then just place on top of each window or door as desired, with each instance adapting appropriately to a variety of fenestration sizes.
Or...
As previously mentioned, you could make a face-based family that you could just place onto a wall and move into the appropriate place at fenestrations, and then adjust for various opening size parameters as required.
Or...
You could take either of those two families described above, and nest it, in turn as desired, into each window and door family.
Sahay_R
1) Create a profile for the trim.
2) In your Window family, create a Sweep using that profile, pick lines from opening to sketch the path.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
leila.k.sh
in reply to: Sahay_R
Thank you, friends,
