Revit Architecture
jmackniak
Message 1 of 5 (553 Views)
Accepted Solution
Winder Stairs
553 Views, 4 Replies
01-14-2013 09:16 AM
i have looked through the discussion board and cannot find an answer to How to create a Winder staircase.
The as built staircase is a straight run with the first 3 or 4 treads winding.  I cannot figure out what my settings need to be etc. HELP!!
*Expert Elite*
Alfredo_Medina
Message 2 of 5 (526 Views)
Re: Winder Stairs
01-14-2013 07:06 PM in reply to: jmackniak
There are, at least, 2 ways:
  • With the stair by sketch method, modify or create risers manually, with the Riser tool.
  • WIth the new stairs by component method, use the Winder tool.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
jmackniak
Message 3 of 5 (509 Views)
Re: Winder Stairs
01-15-2013 05:34 AM in reply to: jmackniak
Al,  Thanks that is what i did.  I drew the stair boundry and placed the risers in. seemed to work fine. I get the error message below:  Stairs require no less than 2 boundries. (the MS paint image dropped some of the risers, trust me they are there)revit stairs.png
*Expert Elite*
Alfredo_Medina
Message 4 of 5 (502 Views)
Re: Winder Stairs
01-15-2013 05:54 AM in reply to: jmackniak
See that green horizontal line? That should be a riser (black line), not a boundary (green line). The boundaries areusually two sets of lines, on the sides of the stairs, not intersecting each other.
jmackniak
Message 5 of 5 (471 Views)
Re: Winder Stairs
01-17-2013 09:11 AM in reply to: Alfredo_Medina
Why isnt this board (not sure what it is called) not running parallel with the stair case??revit stairs2.png
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
