Why does revit have to upgrade when inserting a view?
1 REPLY 1
gbiallas
559 Views, 1 Reply
All I want to do is insert some schedules from a 2013 project into a 2014 project. Why do I have to wait half an hour for the project to upgrade (and temporarily at that since I'm not going to save it) before I can select the views I want? Why can't the views be upgraded when inserted? This makes no sense.
1 REPLY 1
rosskirby
in reply to: gbiallas
Because the views and schedules don't exist independently of the rest of the data in the Revit file, the entire file has to be upgraded before a view can be read and inserted into another project.  A Revit file isn't like a directory of independent CAD files, where you can upgrade one that's xrefed into another without upgrading the host file.  All the views, schedules, and objects exist within a single file, so to get one part upgraded, you have to upgrade everything.
If you find yourself continually pulling the same schedules, views, etc. from a file, consider either adding those elements to your template so that they're available on other projects, or upgrade and save a copy of the other file so that you don't have to wait for the upgrade every time.
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
