Where is the network install like Autocad?
3 REPLIES 3
210 Views, 3 Replies
Is there a network install, not the network license manager, but a one click silent install like autocad has? David
3 REPLIES 3
I just copied the contents of the CD to the server area that my other install images are kept. Then just double click the setup.exe. Kind of messy but it's better than installing off the CD.
John Postlewait
IS Department
George Butler Associates, Inc.
New in 7.0 are network installation image features. So yes, you'll be able to set up a client install similar to the other Autodesk product...similar, not exactly the same.
good :) Steve_Stafford |>New in 7.0 are network installation image features. So yes, you'll be able to set up a client install similar to the other Autodesk product...similar, not exactly the same. David
