try adjusting the font type and properties prior to exporting
try saving schedule out to excel (via txt within revit) and linking excel file into autocad file
try creating pdf of revit schedule and using bluebeam revu to export schedule within pdf as an excel file to link into autocad
(EEJan17...for contest)
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Hey those are archived accounts from 2005 on rivet version which doesn't even apply anymore! Or just for the contest!
not sure...was told any posts that I put the link in for helping others this week should count). I assume its for questions I am helping that just came in. I'll let Autodesk decide this...
I just noticed in the Revit Arch Forums, Unanswered Tab, tons of questions that all show 2005 dates...wierd..)
That's what it said lol but from 2005 and and archived account rofl that's genuine ... There are lots from 2016-2017 which are not solved 😛 and can help people who are still alive
Hmm but probably you have a point I will post it on the EE Hub for clarification
i can't get my revit arch forum unanswered tab to show current 2017/2016 posts...only shows 2015
revit structure shows 1 2015 post
revit mep shows 2017 post
sent an email to Katinka
does your revit arch unanswered tab show only 2005 posts?
It does yes... also older ones
this is occurring across multiple forums...they all show 1 to 3 post of 2017 and the rest are 2005 or older...
i think i will switch to screencast postings for now....
thanks for the heads up....hopefully Autodesk can correct the issue...
