What's the deal with dimension parameters??
10 REPLIES 10
Message 1 of 11
444 Views, 10 Replies
Hello, I need someone to tell me why when I have a dimension parameter I am not able to flex it in the family type box with out constraint problems.How ever if I am in a 2D view I am able to click the reference plane I want to move and then flex it by typing in a measurement in the dimension parameter.
This makes no sense to me, I would really appreciate feedback if anyone has an idea why this is
-Zac
10 REPLIES 10
Message 2 of 11
LisaDrago
Is it possible to post the family you are working on?
If it telling you it is over constrained - then there is a conflict somewhere... It cannot flex everything and have it work properly.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Message 3 of 11
in reply to: LisaDrago
Do you want me to post a picture or the family file?
Message 4 of 11
constantin.stroescu
From my former experience when something alike happens to me , I  observed that it was a problem with one of the two Reference Planes that Defines Origin ....Try to Pin them . It could be unpined....Maybe this is the cause
Anyway  is difficult without having the file... Can you send the file?
Constantin Stroescu
Message 5 of 11
in reply to: constantin.stroescu
Yeah I tryed pinning reference planes to see if it would work but still no luck.  in Blue is the parameter that i want to flex, and in Red is the reference plane i want to be flexing and when im in family types and i try to flex it says constraint error.. but if im in this view and click on the reference plane that the red arrow is pointing to i am able to type in a measurement for the parameter thats in blue..
Message 6 of 11
Anyone ever have this problem or know how to fix it?
I'd really appreciate it
-Zac
Message 7 of 11
CoreyDaun
Post the Family file here, if you could. What release of Revit are you using? It's often difficult to troubleshoot such issues based on an image.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Message 8 of 11
in reply to: CoreyDaun
I'm using Revit Architecture 2012.. I attached the file in the message i sent with the picture above.. But ill attach it again in this message
Message 9 of 11
CoreyDaun
Sorry - I overlooked the attachment!
I've looked into this a little bit, and I see exactly what you mean. It even works as expected if you disassociate the dimension from the parameter, select the Reference Plane, and then manually enter a distance. I haven't been able to find the cause of the problem, though.
I do have a way to make the Family at least functional. Instead of constraining the components from the Reference Plane that they're constrained to now, directly constrain each of the individual components to the Reference Plane  towards the bottom. See attached image.
Message 10 of 11
Wow! I would have never have thought of doing that, I literally tried all possibilities except that. Looks a little funky to have that many dimensions but it works and that's all that matters haha.
Thank you sir, I appreciate it!!
Spoiler
-Zac
Message 11 of 11
Alfredo_Medina
When you deal with diagonals that need to be constrained, there are two good choices: reference lines constrained at the start ponts, or diagonals with their endpoints constrained to horizontal and vertical planes..
Using diagonal reference planes is a bad choice. They require too many constraints to stay in place, and will, most likely, break anyway, producing those errors that you are seeing. I think that is causing you problems in that family.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
